Low Hot Water Pressure in Bahroom and now Kitchen
26 Apr 2009
Shropshire
Hi having a real nightmare - recently changed the bath taps for a mixer unit 1/4 turn...and lost hot water pressure - the pressure on the sink is fine.
Then replaced the kitchen sink tap for a 1/4 turn and now bearly have a trickle!
The Utility and downstairs loo all fine - the en-suite is fine...
Any advice please - is it simply the taps - or is it linked to the bathroom problem first and foremost>?
Worth mentioning that also I have just replaced the en-suite shower and had a pump put in - that sits in the loft and seems to be working ok - starts and shuts down fine...
sounds like you have gravity low pressure system and you've fitted high pressure taps.
read the mi and see what min pressure they require.
probably about 1 bar min.
