Hello,thank you for the previous assistance.
Our shower mixer is supplying hot then cold then hot then cold water,we had a new Mira sequential shower mixer fitted in the summer in lieu of a working but externally corroded and filthy mixer valve (same for same).
The temperature fault is new yesterday,having looked through the many shower threads here gave us some ideas on what to look for.
The combi boiler is a baxi 105ee (not instant) think it's been here 15 years,we are new here.
Watching the boiler when running a hot tap,it fires into action running up to 60 degrees the boiler stops burning gas.The water runs cold for 1 minute then fires up then cycles hot cold hot cold.
The boiler is not maintaining hot water temperature. It does the same when running heating fires up then off then reignite continuous cycling.
The boiler does not overheat or need resets.
Any advice is very welcome,thanks in advance.
