hi folks bit of a strange question for you . I have a shower tray which I am going to fit it only has a 50mm waste v 90mm I have on other shower trays I have fitted.
I know that the flow rate will be limited by the pipe work which I this case drops down to 40m. Then a 32 mm boss.
My question is as this shower will be run off a pump will the standard 50mm waste cope with clearing the water from the shower tray or will it struggle And should I chanfpge the tray for one with a 90mm outlet.
Cheers
Jon
Cheers
Jon
