Hi there clever people,got a simple one for you. I need to upgrade my shower from a 7.5kw(which drips water out very slowly,Mains connected) to a 9.5kw, luckily whoever installed the original did it in 10 mm cable,and clipped it to the wall in the loft area away from the insulation.Length of cable is approx 10 meters.
My consumer unit is split and where the 32amp mcb currently sits is protected by a 80amp RCD. My question is firstly what mcb should i use or do you recomend a rcbo.secondly if i have enough capacity to upgrade to a 10.5kw shower and is there a great deal of difference in performance.This is my first time so be gentle[/quote]
