Have recently moved house and have replaced an electric shower with mixer attached to existing pump feeding another shower. Expected the flow would decrease but it now seems heavier even when both showers are on. Anyone any ideas why. My initial thoughts are there may have been a blockage which I disturbed.
second question maybe need electric forum. The shower pump is attached to a double pole switch at 5amp. This is then run to the consumer unit MCB 45amp. Is 45amp too high. Does it need changing, is it safe. As the pump was put in before I moved here do not have a booklet. if it needs changing will have to get a spark to look at. Any advice appreciated.
