showerpump/hot tank
28 Oct 2007
Buckinghamshire
Hi all I have two gravity fed showers one is a bristan calico in the bathroom next to the airing cuboard with very little flow, the other is a aqulisa 609 in a downstairs I would like to fit a pump. what size pump do i need ? and do i need to increase the size of the hot tank it is approx 1050mm high. thank you
1050 high by 450 wide is about 120 litres Ive read other posts that suggest about 50 litres of hot per person. so something larger that you have would be an improvement
a 2 bar pump should do you, ideally situated next to the hot water cylinder.
