Hi All, and happy new year!
My aged mother's CH system is having problems. Like her, the system is pretty ancient and not functioning too well!
It consists of - Potterton C70/21 BE or SB a floor standing gas boiler.
-Randall 3033 timer controller
-Honeywell V6057 2 port motorised valve (in 28mm)
I would think it dates back to thr 60's.
Whilst she was living in the house (she's now unfortunately in a nursing home) the system was kept going by very enterprising and resourceful British Gas engineers on a yearly plan which is no longer affordable alas. On our last visit the hot water did not materialise when demanded. (The CH system is left on "trickle" to air the house and keep frost at bay) Now in the past, the motorised valve has "buzzed" as it has ratcheted over, but no longer.So , I had quick look at the valve ,as you do, by removing the motor unit from it's backing plate. The valve seemed free enough i.e. turned freely, although the valve body had a slight weep from behind the round backing plate.There might have been water ingress to the motor but I didn't really have the tools with me to look further.Anyway to cut a long story short, when I put the motor unit back I found that I had instigated a strange set of additional symptoms..you know the sort that make you ask yourself " why did I start down this path?"
Now, the boiler fires up irrespective of the controller settings and stays on until you switch the electricity off at the FCU. when it goes to pilot. The programmer can be set on .....constant/timed/off...yes even off! and this is for both CH and DHW although I still don't think the water gets hot as I didn't have any more time to investigate .( the immersion had been on as well)
Anyway, can anyone shed any light on this problem. I'm wondering if I have inadvertently pulled a wire from the motor unit..There are 3 cables entering the unit. I was ever so careful...honest! Could the controller have just given up the ghost at this point, or could a seized motor/ valve cause such malfunctions.
One thing I've just remembered is that if you ask for DHW only, the boiler reverts to pilot after a few seconds, that was before my "investigation"
If the motor and/or valve are at fault , are the modern equivalents a direct replacement? I notice that the existing honeywell unit has no external operating lever.
Anyway , sorry for the long post, hope somebody can suggest ways forward. I'm not due to visit again for a couple of weeks so I hope there will be no freezing spells meanwhile!
Regards,
S.
Regards,
S.
