You can, although they are normally used in commercial construction.I'm not sure whether you can get cavity lintels or housing ties for that width.
Probably not though, as insulation obeys the law of diminishing returns...so increasing from 100mm to 150mm in the walls would give more benefit than increasing from 300mm to 350mm in the roof.You would be increasing the insulation thickness by around 50mm above normal.
That 50mm might be better applied in the roof.
Ah, sorry, I was thinking of full fill insulation.Normally use 100mm celotex or similar with a 50mm cavity on 150mm cavity walls, so you are doubling the thickness.
Wall skins normally need to be at least 90mm thick.
Did build an extension in the early 80's with 75mm blocks on the outer skin, but was told that the render was included in the thickness, unlike tile hanging or cladding.I wonder why 75mm block is not used. I'm sure structurally at least it would be fine if well tied together.
