Siemens Fan Oven
27 Dec 2007
Can anyone tell us what the problem might be? Our Siemens fan oven will not heat up! The Bulb inside the oven works and the grill still works within the oven, but the temperature on the oven will not rise?
Has it got a clock? Make sure the time is set correctly if it has.
Other than that, the oven element or thermostat, or occasionally a broken wire.
Element is the first choice if the clocks set.
