Silicone tube racking
1 Dec 2009
East Mids
Come on all you window fitters, how do you store them, need to sort my van out over the crimbo period and buying or making some sort of rack is a job on the list, also as I carry white, clear, brown, caulk, toffee I need a rack that holds more than 5 tubes, I normally keep a box of each colour on
wonder if you could incorporate a wine rack of sorts into your racking?
I shan't post a pic of mine as its just a pink plastic box with some wood wedged in to separate the colors lol.
A friend of mine has 4 lengths of down pipe attached to his back doors, 1 for clear, 1 for white, 1 for caulk and 1 is mixed colors.
Its very smart but I often fill the van right to my back doors so would need to find space elsewhere to do the same (if I ever get time).
Hes a handy man type of work and his van is immaculate! One very cool trick that I pinched off him is to fit these:
http://www.ebay.co.uk/itm/3528-LED-...hash=item27daf61581:m:mSpP_H0AUWNVA6-RFcfp4RQ
Awesome with the cold dark winters.
You can get them for about £5 without the charger/adapter and make sure you get the bright white ones.
You can stick them to the roof of your van (solvent 1st and run through bulkheads so they don't come unstuck) and the light they give off is amazing!!!
He ran a separate power supply from a socket and put a switch in but my hack was faster and works better, Just wedge the wires in behind the bulb at the back of your van and they come on when you open the doors just like the built in light.
Ive got shelves to the sliding door for all the tools, x3 shelves for all the silicones, each shelf has been sized to get 2 boxes on.
I'm only in a new shape transit connect so room is at a premium, tool box takes up the side door, slide out rack for all all my power tools against one side behind a glass rack and the other side are my tilt bins for screws and fixings/odds and sods
I use old wine rack in the garage for storage of cans etc.
