Sime Friendly balanced flue won't fire
It modulates the gas valve and turns it off when its hot enough!
What did you expect it did?
have you actually tested the flow switch? if am correct the sime has 2 boards next to one another. If the flow switch is proving I would check that the board on the left hand side as you look at the boiler is sending power to the ignition board on the right hand side
