We have a Sime Friendly Format 80e combi boiler that has developed a fault that I hope to be able to resolve but (via a gas safe engineer) we have replaced the main pcb and air pressure part with no joy.
The problem occurs when the boiler the heating or hot water is turned on, the boiler makes the sound as if it is going to fire up but then clicks immediately and doesn't fire up, instead it goes into this loop of sounding like its going to work, clicking and stopping...sounding like its going to work, clicking then stopping etc etc. so the boiler doesn't ever get to the stage where it's lit, it clicks off before then, tries again etc.
The clicking sounds like its coming from the blue Ignition Control box at the front and I understand this contains a PCB also. Could this be the problem?
Any help would be much appreciated as I pray the the thing can be repaired!
