SIME Ignition Problem ....PLEASE HELP
17 Dec 2008
Manchester
Hi All,
Boiler SIME Super 105 MKII has been working perfectly fine up until now. Had it on the timer to switch on - ignition fires it up ...starts clicking ... flame comes on then after 5 secs goes off and repeats cycle. Surely this is straight forward ?
Any help appreciated.
Thanks ;)
Yes its a straight forward fault for a CORGI to investigate.
However as its a combustion safety device then it needs a CORGI.
You could probably replace the ignition PCB yourself but that may not be the the fault and is an expensive part if not required!
Tony
