Hi, I have an ancient Sime super 90 combi boiler.
The diverter valve has been sticking for a while meaning i only have hot water when the heating is on or if i wait for it to heat the rads before the tap gets hot. I also had a leak from a joint on the pressure relief valve.
I have taken the diverter and pressure valves off, cleaned the diverter valve diaphragm and re-fitted them both, topped up the pressure, no leaks.
Now nothing is happening when i run the hot water and with the heating on i have a pilot light and a clicking coming from the pcb but it does not light. As far as i am aware i have not interfered with anything other than the two valves. Any ideas where i have gone wrong or what i may have disturbed ?
