Simple enough question but....,
30 Jun 2008
Suffolk
...I don't know the answer to it.
You take a supply from the main consumer unit to an outbuilding, which has a two-way consumer unit with main switch RCD.
From experience I know that if the RCD trips in the outbuilding, it will often/always trip the one in the main CU.
So, if you don't use, (export?), the earth from the main CU, but instead use an earth rod in the ground at the outbuilding, does this prevent the main CU from tripping.
My brain says yes, as there is no earth connection back to the main CU. But there is something niggling at the back of my brain saying it's not as simple as this.
No it will NOT prevent the RCD in the main CU from tripping.
The current that flows into the earth rod has passed through the main CU on it'e way to the Earth rod but does not return to the main CU. Hence the RCD sees an unbalance and trips
Thanks guys. I knew it didn't seem right. Just couldn't get my brain around it.
As I said, simple question. :rolleyes:
You could presumably use a time delay RCD in the CU for that circuit which would allow the shed RCD to trip first?
