New to DIY. Got a new house which is need of a little TLC. Anyway I've started on the downstairs toilet and took a piece of wood of wood that appeared to be glued to the wall. However contained raw plugs which took some of the plaster off, see below. Depth is approx 3mm.
View media item 50717
Thought a little poly filler could fill it however not so. Can you advise what I should be using?
