12 years ago we had new power showers fitted (Mira). First two pumps lasted about 4 years, third about three years, and the 4th is just over a year old and is about to pack-up. Fitting the pumps are quite straightforward, so the last two I have replaced myself - Salamander Twin Impeller 1.5 Bar. Last time, I called Salamander to see if I could get the warranty extended from two years to three years, I explained the water supply to the pump came via tee from the hot water cylinder and because I didn't have a "proper flange", they told me it was plumbed in wrong, so no warranty would apply. The plumber that fitted it all seems to have lost interest!
So I called in plumber no. 2 to fit a flange, ready for the next pump. He's told me a flange can't be fitted because there's no threaded attachment on the cylinder. Options now seem to be:
a) just keep buying new pumps every 18 months or so.
b) plumber fits replacement vented cylinder with a Surrey Flange
c) plumber fits new Joule Indirect Unvented Cylinder
If I understand correctly, option c) means i) cold water tank in loft can be dispensed with and ii) no need for a shower pump, as all water will be at mains pressure.
My question is, is it likely that the shower pressure will be at least as good as what we are used to? (And are there any unintended consequences of fitting an unvented cylinder?)
