Can some one explaine this, a friend of mine has a 3 phase lath in his workshop connected to a single to 3 phase inverter, he has trouble with the lathe motor phaseing at slow speeds and when reversing, he read in a engineering magazine that if you connected another small "slave" motor across the inverter output it prevents this problem.
I assume the out put from the inverter is not sinusidel hence the phaseing but why does putting another small inductive load across alter things ?
