The likes of the Rufford wind generator uses furlmatic design to bring it out of the wind when wind get too strong, so don't produce either with no or very high winds, they were used on the Falklands which is known for being windy, but to run an electric fence back in late 80's early 90's when I was there, the solar panel did a better job.
I do know the diesel heaters you are talking about, common in narrow boats, but in winter solar panel output is rather low, and you need some other method when the panels can't cope, be it a small generator, or taking the batteries somewhere to charge, that's up to you, but you need a back-up plan.
I would go to a narrow boat forum, they use generators, wind chargers and solar panels, both lead acid and lithium batteries, and can likely help better than on here. I have when using my e-bike gone to pubs and railway stations to recharge the batteries, there is normally somewhere you can take them.
