Hi. I'm wanting to reduce the width of a cubby hole door. I attach a picture. I think it best to add a door post and leave the old one in situ on the left hand side.
The area in red is the new skim of plaster. Note that I will have to lay the thin layer of plaster on top of some elements of the wood door frame, which sits about 1 or 2mm below the surface of the wall plaster.
Will I have a problem with the plaster over the wood areas? Do I need to do something to ensure the plaster does not fall away from the wood areas? Thanks.
