Skirting fitted over wallpaper
16 Mar 2005
I am removing some old wallpaper from my hallway. Woodchip + painted over. Most of it came off easily. It fell off the wall -- seemed the paste had failed after 20 years or so.
The previous owners seem to have installed laminate flooring, then refitted the skirting boards so that they overlap the bottom of the wallpaper.
Hence if I want to completely strip the wallpaper I have to try to "dig it out" from behind the skirting.
Any tips. I don't really want to remove the skirting. But it is a time-consuming job otherwise.
Mike
I think I would use a sharp knife (no not to kill myself), cut careful so as you do not cut the wood, the blade will blunt as it cuts into the plaster, so you may need a few blades.
Yep......sharp knife along the top of the skirting.....then scrape down to it, then, as you said about scraping down the back of the skirting.....there must be a gap....so fill it....thus avoiding having to strip the rest of the paper.
