Hi All,
I have just removed old skirting board, I am fitting new chamfered skirting the two internal walls are cinder block and the other two are brick.
When I removed the old skirting the timber plugs came out, shall I replace the timber plugs or would you fix the skirting using screws and sinking the heads.
What is the best way to fix to cinder block as I find that screws do not always fix to cinder the wall plugs just spin.
Any suggestions pls
Any suggestions pls
