SKY MAGIC EYE PROBLEMS
12 Feb 2009
Yorkshire
Hi there
Can you tell me how i set up my Sky Plus box so i can watch Sky in another room.
I've had it set up for a few years and its been fine.
Recently we've got Sky Plus and it doesn't seem to work now.
On my instructions it says to go to Services, then pres 4 then 0. But there is no 0 in the menu, it only goes up to 8.
Is there a section for RF Outlets on Sky Plus?
Are you running the link to anotehr TV from the RF2 output on teh back of the box? If so you need to turn it 'on' to do this you need to access the engineers menu using the following button presses:
To access the Installers Menu, use the following set of key presses:
SERVICES, 4, 0, 1, SELECT
Then go to the RF output option and turn it on to 12v
Should solve your problem.
Press the numbers on the remote and don't look at the screen whilst you do it! It will put you off (as you say there is no '0' on the sys setup menu.
Services,4,0,1,Select
Down to rf outlets and select
turn the power on
and press select.
If you used a different frequency on the old box and don't know number just retune your other telly.
Also a standard (non sky+) remote will not work with sky+ unless you follow this procedure:
The sequence is:
* TV
* Hold Blue+select until LED flash twice
* 2
* Select
* Sky
