I currently have a two gang switch on a single "square" faceplate in our utility room. One switch is for the utility room light, the other is a 2-way for the garage. It currently has a rather crude neon indicator that shows when the garage light is on (it is just a neon poked through a hole drilled in the faceplate!) which I would like to replace with something a bit more professional. I would like to keep it as a single gang sized accessory and was looking for maybe a grid switch with a couple of switches and a neon, however I can only seem to find 3 modules on a double sized faceplate. Is there a manufacturer of grids that does 3 modules in a single-gang sized faceplate?
Thanks for any replies.
