My dishwasher obviously had a moment last night the cycle was still running this morning. I opened it up to see it full of water and the spray nozzle that attaches to the main spray arm on the base had unattached itself.
I reattached it and continued the cycle to completion only it didn't end with the final bleeps as normal and there was still a small amount of water sat in the base (much less than before so it did pump some out)
I removed all the water with a sponge, made sure all the various filter bits were clean. Then was going to put it on a quick program just to check all is well. Only it won't start a program, when I power it up, all four of the cycle lights and the last program light flash briefly and then go out. No bleeps.
I have tried the hold down program 1 + 2 to reset it, and after reading this forum the press 4 times in 3 seconds but its just the same.
Any ideas?
Any ideas?
