I have added a spur from an existing socket that is on a ring. I have performed continuity tests to confirm that the existing socket is part of a ring. There are 2 cables coming into the existing socket.
I have an older style CCU where overcurrent protection is provided by fuse wire that is mounted in a removable module to BS3036. I identified the module for the associated ring which was rated at 30A and removed it from the CCU to provide isolation. After I had completed the work I put the module back in the CCU. As I pushed the 30A module into the unit I witnessed a spark in the CCU. I removed the module. The fuse wire was still in tact. However when I inspected the wiring for the spur it had been damaged. Why was the spur wire damaged and not the wires associated with the ring? Is this because the ring distributes any current overload throughout the ring. One thing I must add and that is my wife had just turned the hot tap on which is heated by a combi boiler which I did not realise was on the same ring. The boiler is protected by a separate fused point which did not blow. Any help would be greatly appreciated!
