Socket spurs
23 Sep 2002
I know you're not supposed to run a spur from an existing spur (and I'm not planning to!)... but what would actually happen if I did?
You run the risk of overloading the supply cable, causing it to heat up, possibly melt the insulation, cause a short circuit, start a fire.........
However, radial circuits are OK as long as the number of sockets does not exceed the rating of the supply cable - usually 2.5 mm sq.
Power cable is usually 2.5mm which allow 30A in a ring and 20A radially. Now people rely on central heating, power cable rarely gets used to capacity.
The IEE regs are specific on it and you can read them in the library. However in practice the main problem is confusing future electricians. If you adopt non-standard wiring it could lead to confusion and extra labour charges when correcting faults or extending wiring.
depends if it's a fused spur or non fused. you can install as many fused spurs as you like so long as each one is protected by the previous one
don't think the problem is confusing future electricians - most of the good ones will not trust what they have until they've checked it - confusing future diyers is the most dangerous thing, because they don't know what to look for and don't have the knowledge to check properly
