- Joined
- 2 Apr 2005
- Messages
- 109
- Reaction score
- 1
- Country
I enclose a photo of our current waste system which has 110mm Grey Marley Soil Waste and simply runs one toilet into it, as we now have an extension and on the other side of the soil pipe we wish to add a toilet and sink.
what I intended to do is to get this out and put a T-branch of the same dimensions so I can run another soil pipe from next door into the extension I have just had built, this would be at the same level etc.
But after lots of investigation and hardly any space to work, and the fact the pipe is solvent welded below and has another 3 fittings which would mean taking out a fitted bathroom too and kitchen, I don't think this is an option now, the thing is if I started it and it messed up then I have no waste upstairs at all which would not be good. We can't put soil pipe outside as conservatory below etc.
Therefore I am thinking along two lines, possibly a saniflo and go for a more expensive one or a better one but even with this how can you run the 22mm pipe into a branch? I mean can you drill a 22mm hole into one and then cement it in? or can you only do this into the soil pipe itself?
My only other option would be if there was somekind of flexible soil pipe available? so I could hack off the soil pipe further down and have the flexibility required.
Alternativly, is there a specialist type of plumber that could do this or am I asking a lot? as the couple of plumbers I asked didn't want to know as too much trouble (can't blame em).
