Soil pipe connection
8 Jun 2005
Lancashire
I am installing a new wc and am getting a leak from the push on connection to the pan. I have tried 3 differant connectors and each leaks. Has anyone any ideas on how to stop this.
their should be pan connectors to suit most jobs. i take u seen straight ones..off set..dbl offset...kinked ones....swan neck...90degree ones and flexi ones. get the one that strains the jojnts the least and it should fit without leaking
Check the spigot on the wc is reasonably round. If there is a "flat" on the spigot then the push-on will not form a seal.
Make sure the height of the WC spigot is not below the tee into the stack, if this is the case water will not run away properly and will pool in the pipe, this still should not leak but it never helps matters.
Thanks for the replys, if there is a flat spot on the spigot can I seal it with plumbers mait.
If the glaze is missing you won't stop it leaking, as far as I know.
Plumbers mait is in my view totally useless for anything except ballast. You can use silicone but shouldn't have to.
You could try a Polypipe or a Kwickfit connector - their bits of elastic ring are much more accommodating than Multiqwik's. Unfortunately they're harder to get into the soil pipe at the other end.
