Soil pipe Frustrations
5 Apr 2015
Devon
Hi all,
I am currently in the process of refurbishing our bathroom. We are looking at changing the layout which means moving the toilet from one side of the room to the other and having a wet room type shower where the existing toilet was. I was planning on taking the waste out through a new hole in the external wall and then connect into the existing waste externally. The problem is that I hadn't taken into account the pitch of the single storey tenement roof and as such it will be below the level of the roof.
The question I have is, does anyone know of a product that will allow for a pipe to be taken through a slate tiled roof horizontally (or at least almost with the fall required for the waste pipe) I know you can get lead slates for vertical pipe penetrations, can you also get the same for horizontal? And if so can anyone point me in the right direction for these?
thanks
You'd need to employ a roofer with good leadworking skills to make up a special weathering collar for you
If you think about it a horizontal pipe is the same as a vertical one - it penetrates a plane at an angle :wink: calculate the angle and as long as the slate is big enough to weather, you're done . Might even be better with one that has a rubber seal to the pipe rather than a loose lead one .
