Soil Pipe - Solvent Weld equivalent
11 Dec 2019
I've just succesfully drilled a lovely 125mm hole through the house wall. I've just realised that my 125mm is not enough room to fit the 90-deg push fit elbow ( https://www.screwfix.com/p/floplast-push-fit-92-5-single-socket-bend-black-110mm/70115 ) that I wanted to run my soil pipe along the wall as the push fit collar is larger than 125mm......
A solvent weld joint would fit though......
Is it OK to get a solvent weld equivalent of the above and am I OK to mix and match solvent weld 110mm pipes and maybe brands as well? - Screwfix don't seem to have what I need
Regards
Tet
Yes ,solvent weld bends are available from most decent plumbers merchants. I find it best to stick to one brand for all the fittings and pipe ,but in theory they should be compatible between brands.
