- Joined
- 26 Mar 2016
- Messages
- 1
- Reaction score
- 0
- Country
With the weather being good over the past few days I've been tidying up the garden. When tidying around the back I noticed there was waste water that appears to be from the bathroom but maybe the kitchen sink gathering around where the soil pipe enters the ground. I am now thinking if its blocked or it is leaing out of a loose seal.
The soil pipe drops down from the second floor, the toilet goes into it first then further down the pipe is an inlet fromthe kitchen sink before going into the ground and I presume there is 2 90 bends to take the pipe into the cellar and down the wall into the sewer. I've taken some photos to help show you better.
As you can see, where the kitchen waste pipe meets soil stack is a very loose fit, I noticed the seal wasn't attached properly so thought water could be leaking from there? I did try refit the seal but failed and the seal dropped down the soil stack. Should I just buy a new one and refit it or do I need to try and fish it out?
Failing this, could it be the soil pipe is blocked somewhere? My guess is between the 2 90 bends. If so what should I do to fix this?
Thanks a lot in advance for any help!
