soil stacks
4 Jan 2006
Southampton
I am installing a downstairs toilet in my extension. I have run a soil pipe down the side of the house to the sewer but becuase it is such a long run (about 15m) and due to the slope of the ground, it gets very close to the surface at its highest point, just a couple of inches below. Is this ok? I intend to cast a concrete path down the side of the path later which should protect it.
Also, if the toilet (with basin Teed in) pipe comes horizontally out the wall, do i simply connect it to the soil pipe with a couple of elbows? or do i have to use one of those large radius bends? If this is the case, there isnt enough height difference to accomodate this. What should i do?
thanks
quote="browfish"]I am installing a downstairs toilet in my extension. I have run a soil pipe down the side of the house to the sewer but becuase it is such a long run (about 15m) and due to the slope of the ground, it gets very close to the surface at its highest point, just a couple of inches below. Is this ok? I intend to cast a concrete path down the side of the path later which should protect it.
thanks[/quote
You are probably the only person in the world who knows what you are talking about.
What get`s closest to the surface? you can`t just bang in a soil stack & tie in all sorts of appliances, lengths, gradients, number of appliances & all sorts have to be taken into consideration. Another short cut merchant who will be shocked after doing it all himself & finding out his house always smells of sH**it.
browfish said:
Is this ok?
What should i do?
No. Bamber is right.
Also, bearing in mind that your proposed work is subject to Building Control, the best person to ask your questions of is your LABCO.
Softus said:
browfish said:
Is this ok?
What should i do?
OOOh yeeah Don`t forget to inform building control because if ya don`t ya might be in trouble, this from a software nerd , part time plumber,jeezus these comedians aren`t even friggin` regulated..go figure :wink:
