- Joined
- 3 Apr 2017
- Messages
- 11
- Reaction score
- 0
- Country
I'm about to wire up my Solar iboost but i don't understand why my single top immersion has 2 cables and what to do with cables when it come to installation.
is this mine
Dual Element Immersion Heaters
The elements should be controlled through separate thermostats. In practice the thermostat for the top (short) element is usually set 5-10°C less than the thermostat for the long Off-Peak element.
The 3 core flexible cords should be heat-resistant and rated 85°C. TERMINAL 4 (boost live output) should be connected to the short element and TERMINAL 5 (Off- Peak live output) to the long element.
The Neutral connections should go to TERMINAL 3 and the Earth connection to the EARTH TERMINALS.
is this mine
