solar powered extractor fan
Honeywell T6360B thermostat has change over contacts SPDT, adjustable from 10-30 degrees c.
I thought most stats come with terminal contacts normally open and normally closed. So the stat would close the switch when the temp rises above the minimum heat temp that is set. ie. normally closed.
or am i missing somthing here?
But that one is the odd one out, it has spdt contacts and iirc a hysteresis resistor.
