Hello, just coming to the end of my project and am getting worried that I may have cocked up the soldering (solder ring fittings) and that on filling the system they will all leak!!!
I just wanted to check some things please...
1. I noted from the FAQs that overheating of joints can be a common problem. I’m now worried I may have not heated enough. Some of the joints have a lovely reassuring lot of solder around them, others have only a bit visible but not necessarily all the way around.
Is this ok?
2. If this is not ok is it re-heatable?
3. If there are leaks I assume you have to drain down again but do you have to replace the leaking part or can you re-heat?
I realised the last time I did this was many years ago and I’ve lost the confidence of youth!
Also, last time was on mains water so easy to switch off and fix. This is a heating system.
Thanks for any words of encouragement.
Is this ok?
