Soldering a watering can
29 Jul 2004
Bristol
The joint on the base of a galvanised watering can is leaking.
What type of solder and flux is used to repair it?
If the joint is leaking because it wasn't formed properly, you could probably use a roofing/gutter sealant around the inside.
If it's rusted through, any repair is going to rust again unless very well treated.
There is a chance that if you have a blowtorch to get the area hot enough, you could get some solder to stick, but I think it'll test your patience!
It'll never weld in a million years. Never solder either. Run a bead of silicone around the INSIDE of the can and it'll be good as new.
To elaborate the can was left outside over winter with water in it and the water froze which expanded and pushed the bottom out into a convex shape so that it would not stand up as normal.
I hammered the base flat aware that it may break the joint between the base and the side and it now leaks.
I tried soldering using plumbers solder and flux but it would not take so I will remove that and hammer the joint flat to get a good a seal as possible then apply some silicon to the inside of the joint.
thanks for all your advice
Most of the galvanised watering cans I've seen had rolled seams around the base, like an oversized tin can. A bit of water lodged in the seam, and a winter frost may have sprung the seam, unrolling it enough to cause a leak.
I would go with a bead of sealant around the inside.
Galvanised steel should solder nicely with the right flux (probably something like Bakers No. 3) and a lead bearing solder, using a large hatchet shaped bolt (soldering iron) and a few years experience. The old adage was a good tinman could solder a cat's tail to a brick wall.
It's one of those repair jobs that could end up as rebuilding the whole watering can, as patching the leak just chases it further round each of the seams in turn.
All you need is a band of Tinkers :idea: they will fix it - and nick half your other tools :roll: :lol: . Got many round your way :?:
