I have some slightly dripping compression joints, they wont tighten anymore and they need replacing.
When I drain the system, I would like to replace them with pre-soldered elbows.
I heared a rumour that it is not a good idea to use pre-soldered joints on pipework that still may contain a bit of water, as when the blow torch heats up the joint, the water can corrupt the soldering process.
Is this true? Is there a good way of soldering joints onto central heating pipework that may still contain traces of water or should I replace the joints with more compression joints.
Any help will be much appreciated.
Cheers..... John
Cheers..... John
