Afternoon all,
First time posting after months of loitering
I would be very grateful for some advice, I have read all advice but cannot find answers to the below questions!
50m2 (3 rooms, one corridor) of real wood flooring (140x20xmin1500) to be put down on existing pine floorboards. Existing boards have localised legacy woodworm damage, plus a slight slope in one room.
Easiest method is to float perpendicular to existing boards on top of 3mm underlay, but the manufacturer's guidance state nailing only (sadly).
Questions below:
1) How do you determine whether your existing boards are level/flat enough to be nailed to directly? Whats the criteria?
2) The corridor favours planks to be laid along it's length. Rooms favour it being laid running away from windows. What happens if this has your corridor boards perpendicular to the room boards? Does it look OK?
3) Irregular room shapes. You have a rectangular room with the door on one short wall (3m) and the window on the opposite short wall. The two long walls (4.5m) aren't parallel. Where do you start?!!
3) Does anyone have any experience of GoodFellow flooring? Namely: http://www.goodfellowuk.com/node/91
All help would very gratelt appreciated.
GW
Questions below:
GW
