Not sure if I've put this in the right thread.
Bit of background on the house.
We have an old stone farmhouse (traced it back to 1850, but it's older than that) walls 600mm thick - rubble stone (not good quality stone) which has been spar'd over in the 1960's. Interior walls - think they have been tanked with a slurry mix - the floor apparently was timber but replaced with concrete walls (2007 before we purchased it in 2009) tanked at that time. The house is built on solid rock (as we found out when building new extension - kango/pick axe job to parts, then parts which were over a meter of 'infill earth' down to find a solid base for footings.) When hacking off some of the spar to join in the new cavity of the Ex we found it 'killed' the old stone so hacking off the rest is a nogoer. Interior wall plastered and is the same situation - so again we are not able to hack it all off with out damaging the stone.
What we want to do...
We want to insulate the interior walls but there is some 'damp' to the walls, this is most probable caused by the spar getting hairline cracks - which we can't see but after 40 years must be there. Traffic in the lane has increased since pony and trap days to farm machinery taking up the full width of the lane...!! Weights have increased from a couple cwt to tons...! plus they now drive at 90miles an hour....!
We are going to re-render over the spar (your comments on this would also be appreciated) We are worried about causing more damp (is called intestial?) to the walls behind the insulation.
How would you go about it; the house is only one room wide so losing on the width is an issue, so keeping things to a minimum while getting the best u-value.
Any helpful comments/suggestions would be appreciated.
OHhh...... PS: My otherhalf was a builder now retired or is that just tired... !! while used to the 'old ways' is not up to speed with some of the 'new' technology.
