Hi, just joined this site, can someone advise if I can lay 18mm solid oak flooring onto a concrete floor that is covered/sealed with what I assume is a bitumen product. I have been told by Seka technical department that the bitumen needs to be removed, this seems drastic, and contrary to what others are saying, if this is not the case what is required, the bitumen seems hard to the touch and is pretty well level, would it be better to cover the bitumen with a screed ?, or, just PVA it, then glue the 120mm planks of solid oak?, grateful for as much info/advise as possible, as I am desperate to get it right first time. goafer.
