SOLID WOOD AND BITUMEN
18 Sep 2010
Manchester
Any advice would be really welcome - we have a bitumen floor so I understnd that we cant glue a solid wood floor to this therefore what is best option.
1) Fit an enginnered floor - the fitter at our local store advised this was best on bitumen flloor or
2)Can you fit a floating solid wood floor that is not glued down - does it have to be glued or can you buy solid wood floors that click together and float or does it have to be glued together possibly causing cupping etc as real wood expands with seasons.
any advice really welcome - we just fancied a solid floor but it seems engineered may be best. Thanks
I used to do floor laying for my uncle in the holidays and overnight/weekends when I was at college and we used to stick solid wood blocks down with bitumen. Synthaproof I think was best as if the floor was ever flooded the blocks stayed firmly stuck.
Problem is: you can't use Bitumen inside the house any longer - due to VOC regulations.
SYNTHAPRUFE is a DPM, not a adhesive:
"IKOpro Synthaprufe Original is a high performance, brush applied damp proofing emulsion containing synthetic rubber latex which provides a seamless waterproof and vapour resistant, black elastomeric membrane."
I had a little trouble with the Ruberoid link, but corrected it and a direct cut and past from their web page
•Performance adhesive for unsealed wood block flooring
My Uncle was using it until about 4 years ago when he retired.
