Hello. My solo 2 cuts in and out (2 sec cycles) and after a while will cut in as it should . If i press the lower removeable case it will cut in straight away. Sounds like there is a bad connection which I am remaking with this case prod ! Thanks for any help
the boiler on light is on and the fan light on is flashing in synch with the cutting in and out. Now i have taken the lower panel off, gently pressing the small grey box to the left of the lights stops the prob and the boiler works fine until i let go. The question is what is the likely cause of this problem.
