The last tenants complained the water bill was too high, so Severn Trent came out and did some tests to look for a leak.
We eventually found that the downstairs toilet was dribbling water in to the pan. I was able to find out pretty easily that a rubber seal at the top of the bottom entry fill valve had split, so replaced it. Job done. Or so I thought.
That new seal doesn't seem to have stopped the silent dribble in to the pan. So I looked at the flush valve, gave the rubber seal a clean and reattached it firmly. Still dribbling.
So I took apart the fill valve again and found that water was still dribbling up the pipe even though the stopcock was tightly turned off. If I turned a tap on the house no water would come out. If I turn the stopcock back on of course the water flies out of the pipe as I had removed the fill valve.
Is it normal for this to happen? I thought the stopcock should kill the flow dead completely.
