Soptlights tripping mains
28 Jun 2006
London
Hello,
Recently both set's of spotlights in my home (1 in living room, 1 in hallway) have stopped working for the first time since moving here in 2004. Assuming the bulbs had gone i changed them all. All the bulbs that i took out were 50w and i have changed them (20w in the living room and 35w in the hallway as i could not find 50w spotlight bulbs with the correct pins). The spotlights still do not work and if i try to switch on the set in the hallway, it trips the mains switch. Please help!
When you say "the main switch" do you mean an RCD that has a Push to Test button on it?
What is written on this thing that trips? Does it say for example "B6" or "63A 30mA"
And what else goes off when it trips?
Have you made any changes apart from changing the bulbs, or has any work been done on the house, for example drilling or nailing into the walls or floors?
What voltage were the old bulbs that you took out, and what voltage are the new ones that you put in?
