Soundproofing?
8 Dec 2014
Sussex
We've got a converted garage that is currently my son's bedroom, then across the hallway we have a reception room with a big open arch (approx 2.5m wide) instead of a door. I've tried to illustrate this in the image attached. All are brick walls.
Does anyone have any simple (ish) suggestions on how to dampen the sound from my sons room?
Maybe something I can line the walls with on either side that won't take up too much space?
My son's door is also pretty lightweight. Would replacing that and making sure it's a good fit help?
I'm not expecting miracles, just a little reduction for now would help. We're planning on reconfiguring the house in the future, so that living and sleeping spaces aren't mixed.
Fix the door problem first.
A couple of fire doors, one for the garage and one for the arch.
No point in lining walls whilst you have a gaping hole for sound to pass through.
If the garage has room, using rockwool and plasterboard would help make it more soundproof.
You could just do the hall wall and do area.
As said, a fire door well fitted with no holes helps.
You could get magnetic seals routed into the door and frame.
You can get fire door seals that double up as acoustic seals, whether they make much difference I don't know but I suspect they're little more (costly) than standard fire seals so probably worth a punt.
