Can somebody advise me of a retailer who provides a 12v wiring loom to 3 lights (halogen down lighters). The lights originally came from Wickes and the last light on the end of the radial circuit keeps cutting out but can be restored by moving the wire so assumes needs to be replaced.
I can understand the sense behind the use of junction boxes but not knowing where the cable is damaged i.e. could be point of connection with bulb, can you buy a bulb connector?
