Space Saver Stairs Vs Steep Normal Stairs
1 Oct 2012
Kent
All things being equal, and regulations aside.... what do you consider to be safer....
A. 48 degree 'normal'' stairs
B. 56 degree 'space saver' stairs
Thanks :D
Regs require 42 degrees Max in domestic stairs, and they are much safer than space saver stairs.
Thank you for replying, but I did specifically state "regulations aside".
I can't see space savers being that pleasant to use and our 1900 terrace stairs were made at approx 50 degrees anyway.
I think A. would be safer, albeit pretty horrendous.
I designed my own staircase to be 38 degrees. I consider that future-proofed ;-)
Cheers
Richard
38 degrees would be nice. But when you have only 2360mm floor space to rise 2640mm - soon run out of options! :D
I apologise, i thought that you were claiming 48 degrees as a "normal" stair angle.
Stay away from the space saver design if at all possible. Besides the safety angle there is the fact that you dis-bar various groupings, eg the old, from using the flight.
And come house sale time they are not everyone's cup of tea.
Modern domestic stairs are at approx 36 - 38 degrees FWIW.
Yes I see the issue - the going on mine is 3300.
Is this just a straight staircase or does it turn at the top or the bottom? What sort of space is it going into?
Cheers
Richard
Is this for a loft conversion?
Although the Approved Document details sizes of treads/risers and pitch etc, the regs allow flexibility if the staircase serves only one room.
Have you considered a drop landing at the top, to give more space?
You would get a lot more information if you answered Tony's question.
Are stairs for loft conversion or to replace existing?
Regards oldun
