I have an older style 7way MK consumer unit which is all RCD protected and the whole house goes down when anything happens.
I have purchased an new MK 12way split load unit complete with breakers, but now wonder which circuit to connect to main breaker and which to the RCD breaker.
I currently have 1 cooker, 1 shower, 2 Ring, 2 light, 1 immersion circuits, all from the original 20 yr old build.
I want to connect a additional ring for the kitchen and as the immersion circuit is currently used to feed the garage, I want to supply the outside separately and regain the immersion.
Incidentally, the current shower is a 9.5 KW Triton, on a B45 breaker. The supplied breaker is B40.. will that be OK or should I use the original 45, which being all MK looks about the same size although very slightly differnt in looks.
I have been quoted between £300 - £ 750 to do the job and upgrade earth to 10mm.
