Spot lights in bathroom
25 Dec 2008
London
Am about to replace 3 tube lights in our bathroom with 5 spotlights rating IP65. Please advise on how to wire the one light which will be within zone 1.(above shower) outside the 2.25m height as i have read i need to protect any lights within zone 1 with 30ma RCD.
Is it within regulations to secure a piece of ply(9ins wide) across the joist,
directly above the fitting so the loft insulation is away from the light fitting above the ceiling.
Thanks in advance
Ash
1) Have you thought about the fact that you're planning on replacing efficient lighting with inefficient? Do you think that increasing your electricity consumption in order to get a dimly lit bathroom is a good idea?
2) The location you describe isn't Zone 1, it's Zone 2 - you should probably become more familiar with the Wiring Regulations before doing electrical work in special locations.
3) This work is notifiable, and you may struggle to get LABC to agree with you making the lighting less compliant with Part L than it was before.
4) What you propose for the insulation won't do - firstly it may be another way that you make the house less compliant with Part L, and if you don't seal the holes you cut in the ceiling then you'll be in contravention of Part C. See these:
http://www.nhbc.co.uk/NHBCPublicati...ical/StandardsExtra/filedownload,16553,en.pdf
http://www.aico.co.uk/firecap_loftcap.htm
ban - all sheds
thanks for your honest opinion. i will not be fitting spot lights as have chosen to fit a single surface mounted light fitting(4 lamps).
thanks again
